ScottChapman
Jan 26, 2014Apprentice
how to configure iStat on OS6?
I got iSTat installed and running. But launch button is not active. It does day what port to use, and what the default password, question is, what is the URL? I tried http://<NAS>:5109 but get a...
ScottChapman
Jan 28, 2014Apprentice
doylmi wrote:
ScottChapman wrote: It's free on the android. But my experience is above... No idea not to establish my "passcode"
Or stated different, there is no charge for the one I can't get to work! ;-)
No problem, please use the following steps:
[list=a:3c0klogw]Go to the main screen (the one that lists your NAS device(s)). Press and hold your finger on the one you want to update the passcode for. Click "Edit" when the context menu pops up Scroll to the bottom, and update the passcode Press save
I'll make sure this is clearer in the next iteration. Will probably prompt for the passcode iStat is detected, but the passcode is missing.
So, I see how to enter my passcode, but my question was really what is my passcode??? I do not know how to establish or otherwise determine what my passcode is...
