Averenix
Apr 22, 2012Follower
How to configure rtorrent in rutorrent by WhoCares
Hi,
Thought I'd post this for anyone out there like me who bought the rutorrent package by WhoCares (http://readynasxtras.com/readynas-sparc-add-ons/rutorrent-rtorrent-sparc) and wanted to configure it.
Settings not Saving
With the rutorrent plugin, some settings are rutorrent specific (e.g. RSS downloader, Autotools) and some are rtorrent specific (port number, upload/download limit, etc). Adjusting the rtorrent settings via the rutorrent interface does not work and has to be done via .rtorrent.rc.
Permissions
When I first installed rutorrent it had no access to my media share so torrents wouldn't download. To fix this:
Also it wouldn't save any rutorrent settings such as my RSS settings, to fix this I did:
Configuring rTorrent
By default, rtorrent is installed in such a way that you can't configure it using an rtorrent.rc file (as mentioned above, this is necessary to configure rtorrent options - rutorrent doesn't allow it)
To make it use an rtorrent.rc file:
rTorrent will now use the rtorrent.rc in /c/home/admin. Configure this as you see fit.
Hope this helps someone out!
Settings not Saving
Permissions
- SSH into the ReadyNas
- cd /c
- chgrp admin <your-media-directory> -R
- chmod g+wr <your-media-directory> -R
- cd /c
- chown admin:admin .rutorrent -R
- chmod ug+wr .rutorrent -R
- cp /usr/share/doc/rtorrent/examples/rtorrent.rc /c/home/admin/.rtorrent.rc
- Edit /etc/frontview/addons/bin/RUTORRENT/RUTORRENT_service
- Change the last line to '/usr/bin/rtorrent -o scgi_local=/tmp/rutorrent.sock -o port_range=${PORTRANGE}' (You are removing the -d and -n options)
- Restart ReadyNas
1 Reply
- VatoeAspirantThankyou for your guide - it was very helpful to me. Maybe for the noobs out there like me, with your mention the editing of the RUTORRENT_service file, it would be easiest to copy it to /home/admin/ for editing, then copying back:
* cp /etc/frontview/addons/bin/RUTORRENT/RUTORRENT_service /c/home/admin/RUTORRENT_service (edit file from within this directory using an appropriate editor)
* cp /c/home/admin/RUTORRENT_service /etc/frontview/addons/bin/RUTORRENT/RUTORRENT_service (copying the file back)
Some useful settings re how to configure the rtorrent.rc file can be found here: viewtopic.php?f=36&t=62018#p359262
I just have to work out (meaning get assistance) to get the rutorrent service to auto start when the NVX powers on....
