Linda2
May 14, 2012Aspirant
How to Reboot ReadyNAS Pro 4 through command line?
Hi, I have a ReadyNAS Pro 4, which was working fine since yesterday and now from a server on the same network I can ping my readynas IP and I can ssh into the ReadyNAS as well, but I don't get the ...
Linda2
mdgm wrote: Do you have any add-ons installed?
tail /var/log/frontview/error.log
Really appreciate your prompt response.
I did manage to call somebody near by the ReadyNAS and asked them to reboot it for me. After reboot, It all works fine and I can now access the frontview.
But, still would be good to know what caused the issue and if that would happen again later!
Yes, I have Egnyte Cloud back up add-on and Replicate as well.
The result for trail gives me five lines of:
dir: `/c/ELC/.log': Permission denied
chmod: changing permissions of `/usr/local/bin/egnyte/esystrace.sh': Operation not permitted
Would that give you a hint on what was going on?
Thanks again.
