Linda2
May 14, 2012Aspirant
How to Reboot ReadyNAS Pro 4 through command line?
Hi, I have a ReadyNAS Pro 4, which was working fine since yesterday and now from a server on the same network I can ping my readynas IP and I can ssh into the ReadyNAS as well, but I don't get the ...
mdgm-ntgr
May 14, 2012NETGEAR Employee Retired
You mean output of the tail command I gave?
I'd suggest contacting Egnyte about this issue as it clearly appears to be related to the Egnyte add-on.
Typically when Frontview access is lost the solution is to fix problem and restart Frontview if manually rebooting (safely shutting down pressing power button briefly twice) doesn't address the issue.
