Linda2
May 14, 2012Aspirant
How to Reboot ReadyNAS Pro 4 through command line?
Hi, I have a ReadyNAS Pro 4, which was working fine since yesterday and now from a server on the same network I can ping my readynas IP and I can ssh into the ReadyNAS as well, but I don't get the ...
Linda2
mdgm wrote: You mean output of the tail command I gave?
I'd suggest contacting Egnyte about this issue as it clearly appears to be related to the Egnyte add-on.
Typically when Frontview access is lost the solution is to fix problem and restart Frontview if manually rebooting (safely shutting down pressing power button briefly twice) doesn't address the issue.
Thanks, will follow that up with Egnyte, if ever happen again.
