Linda2
May 14, 2012Aspirant
How to Reboot ReadyNAS Pro 4 through command line?
Hi, I have a ReadyNAS Pro 4, which was working fine since yesterday and now from a server on the same network I can ping my readynas IP and I can ssh into the ReadyNAS as well, but I don't get the ...
mdgm-ntgr
May 15, 2012NETGEAR Employee Retired
What's the output of
Can you try restarting Frontview?:
If you are accessing the NAS remotely note that you can pipe Frontview over SSH. See http://www.readynas.com/forum/viewtopic.php?f=65&t=46303
df -h
# /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -t && /usr/sbin/apache-ssl -f /etc/frontview/apache/httpd.conf -k graceful
