daveswee
Mar 25, 2025Follower
How to transfer a folder from my PC to my ReadyNAS
Hi, I'm trying to transfer folders (not just files) from my PC to my ReadyNAS RN204 storage device using the web interface. I can see how to transfer files but not folders. I haven't been able to ma...
Mar 26, 2025Guru - Experienced User
daveswee wrote:
I haven't been able to map the ReadyNAS to my PC using its IP address so I need to use the web interface.
How are you trying to do this?
Assuming a Windows PC ...
You can try this test:
- If you are using the default admin password (password) then change it to something else.
- Open CMD from Windows and then enter:
net use * /d /y
net use z: \\nas-ip-address\data /u:admin nas-admin-password
replacing "nas-ip-address" and "nas-admin-password" with the real values of course.
The second command should mount the full data volume as drive letter z.
If this test works, then you can try creating a user account on the NAS. Then enter the credentials (username and password) for the account in the Windows Credential manager.
After that you should be able to access the NAS with file explorer by entering \\nas-ip-address in the address bar. You can also map individual shares to drive letters. But mapping the full data volume requires using the NAS admin credentials.
