adb1's avatar
adb1
How to upgrade from Twonky 6.0.32 to 6.0.34
I have Twonky 6.0.32 but Frontview says Twonky 6.0.34 is available and there is an Update button, but the release notes at viewtopic.php?f=47&t=41150 say I should remove the previous version first.
Having read some bad stories about upgrade, is it safe to press the Update button in Frontview?
  • I had 6.0.32 installed, and easily upgraded to 6.0.34 by clicking the "UPGRADE" button. Then, just to be safe (but mostly because I like clicking buttons), I changed the "Delete and Rebuild" switch to Yes and hit save. It's working like a champ for me.
  • OK, I did it without ticking the box, but it did a rebuild anyway and it also renamed my share Photos to Pictures and reset my server name back to MediaServer. Other than that it was OK.
ProSupport for Business
