eton
Sep 19, 2013Luminary
How? Transmission Remote GUI path for containing folder
How do I setup Transmission Remote GUI path to open containing folder in the OS X client? Transmission Remote GUI > Tools > Connection options... > Paths These settings does not work:
eton
Oct 28, 2013Luminary
Thanks. Ah, i misunderstood the example.
This seems correct, but doesn't work on OS X:
Nor did this:
I can find a lot of success stories for making this work on PC, but no luck setting up folder path on OS X with Transmission Remote GUI 4.1 so far.
/c/media/BitTorrent=/Volumes/media/BitTorrent
Nor did this:
/c/media/BitTorrent=afp://duo (AFP)._afpovertcp._tcp.local/media/BitTorrent
