eton
Sep 19, 2013Luminary
How? Transmission Remote GUI path for containing folder
How do I setup Transmission Remote GUI path to open containing folder in the OS X client? Transmission Remote GUI > Tools > Connection options... > Paths These settings does not work:
nasischijf
Oct 29, 2013Aspirant
eton wrote: Thanks. Ah, i misunderstood the example.
This seems correct, but doesn't work on OS X:/c/media/BitTorrent=/Volumes/media/BitTorrent
Nor did this:/c/media/BitTorrent=afp://duo (AFP)._afpovertcp._tcp.local/media/BitTorrent
I can find a lot of success stories for making this work on PC, but no luck setting up folder path on OS X with Transmission Remote GUI 4.1 so far.
The following has been working for me:
/data/Transmission/Downloads/=afp:\\HostnameOfMyNAS\Transmission\Downloads\
