eton
Sep 19, 2013Luminary
How? Transmission Remote GUI path for containing folder
How do I setup Transmission Remote GUI path to open containing folder in the OS X client? Transmission Remote GUI > Tools > Connection options... > Paths These settings does not work:
mdgm-ntgr
Oct 30, 2013NETGEAR Employee Retired
nasischijf this forum is for legacy ReadyNAS. With the new OS that you are running there are different mount points.
