michelefaccini
Sep 24, 2011Aspirant
httpd.conf
Hi,I finally managed to setup MySQL and PHP5_5.3.8-rnx86 1.4.1.....I have now to modify my httpd.conf and I would like to know where this file has to be saved : in usr/share/apache/default-configs...
michelefaccini
In the directory you specified,there is the file MYSQLON.conf : if I create one like you said 'michele.conf',what do I have to do to have 'michele.conf' loaded and not the other one....désolé sphardy mais tu as affaire avec un novice....donc si tu peux m'expliquer plus en détailles.....
