michelefaccini
Sep 24, 2011Aspirant
httpd.conf
Hi,I finally managed to setup MySQL and PHP5_5.3.8-rnx86 1.4.1.....I have now to modify my httpd.conf and I would like to know where this file has to be saved : in usr/share/apache/default-configs...
michelefaccini
In fact I have to modify what is it specified as the DocumentRoot (line 305 of httpd.conf which is under usr/share/apache/default-configs/apache) and <Directory /> (line 334 of http.conf) to reflect where I'm going to put my web site (I create a share called my_site) so I need to change line 309 from DocumentRoot /var/www to DocumentRoot /my_site ....same for line 334 which is now <Directory /var/www/> to <Directory /my_site/> is it correct.......I asked if it was only necessary to overwrite this file like this and if in the same position or if this file has to be saved elsewhere....
