lachris
Nov 14, 2011Aspirant
Install python on DUO
Hi, i read all posts in the forum about that. Also made all steps described in http://iandykes.blogspot.com/2010/10/install-python-26-on-readynas-nv.html. But I cannot get it work. When i pe...
lachris
i use a usb-serial converter for logging my heatpump over rs232
the converter is working so far, but for the logging i need some extensions of python
but i think the duo is exact the right for that
the script for logging the pump is not so big, but is using rrd and a deamon for creating some png´s
i will try to add these modules manually
