ricostuart
Jul 05, 2012Aspirant
just updated, now cant access transmission
I have the NV+ which was running the t15 beta which worked fine. Now updated to the release 4.1.9 and now transmission keeps saying connection refused. I have rebooted the readynas as well as the tran...
mdgm-ntgr
Jul 05, 2012NETGEAR Employee Retired
Do you get an error when you try to re-install the add-on?
There is a known bug that led to some add-ons failing to remove properly meaning that when you went to re-install them the NAS thought they were already installed and thus failed to let you.
This can easily be resolved. Do you have SSH access?
