ricostuart
Jul 05, 2012Aspirant
just updated, now cant access transmission
I have the NV+ which was running the t15 beta which worked fine. Now updated to the release 4.1.9 and now transmission keeps saying connection refused. I have rebooted the readynas as well as the tran...
mdgm-ntgr
Jul 06, 2012NETGEAR Employee Retired
If add-on is uninstalled check to make sure that there are no entries for Transmission in /etc/default/services
