ricostuart
Jul 05, 2012Aspirant
just updated, now cant access transmission
I have the NV+ which was running the t15 beta which worked fine. Now updated to the release 4.1.9 and now transmission keeps saying connection refused. I have rebooted the readynas as well as the tran...
mdgm-ntgr
Jul 06, 2012NETGEAR Employee Retired
The ReadyNAS Ultra/Ultra Plus/Pro would be what I would go with. Do note that as the RAID format is different so you would need to backup the data off your NV+. If you wish to reuse the disks from the NV+ they would need to be wiped (delete the partitions off the disks using a PC, then put the disks in the new NAS and they will be formatted).
When did you purchase your NV+? Would you still be within the return period offered by the reseller you purchased from?
