ricostuart
Jul 05, 2012Aspirant
just updated, now cant access transmission
I have the NV+ which was running the t15 beta which worked fine. Now updated to the release 4.1.9 and now transmission keeps saying connection refused. I have rebooted the readynas as well as the tran...
BikeHelmet
Jul 07, 2012Aspirant
If I remember right Transmission's install also times out, so it fails to install and fails to start. You have to let it sit for about 15-30 mins on the NV+ units, then reboot your NAS, wait another 15-30 mins, and then it starts itself up.
I think you have a different problem, but I remember being confused that I kept getting error messages and that it took so long to start.
