shadowboxer's avatar
shadowboxer
LAME add-on
Hi!
Does anyone know of any projects to build a Radiator add-on to install LAME on the slimserver software on the ReadyNAS pro. My search on both this and the slimdevices forum have come up short.
Thanks in advance
-=dale
  • something like that on x86?
    Skywalker:/Develop/lame-src/lame-398-2# lame
    LAME 32bits version 3.98.2 (http://www.mp3dev.org/)
    usage: lame [options] <infile> [outfile]
    <infile> and/or <outfile> can be "-", which means stdin/stdout.
    Try:
    "lame --help" for general usage information
    or:
    "lame --preset help" for information on suggested predefined settings
    or:
    "lame --longhelp"
    or "lame -?" for a complete options list
  • super-poussin wrote:
    try this : Lame for x86
    Super Poussin!
    Thanks, thanks, thanks! :D
    Ka-ching goes the sound of your pay-pal account!!
    The Lame installed beautifully on my Pro and is running well.
    -dale
  • Does this plug-in work with firmware 4.2.7? Doesn't seem to install anything.
    Worked here :427 on NVX.
    To check : got to settings of Squeezecenter, choose AUdio settings of Player and it should say that lame is correctly installed as as comment on the page.
  • I am looking for LAME for ARM to install it on my ReadyNAS NV+ V2. Any help available?
  • Me too, looking for Lame add-on for AMR (Duo v2), anyone that can help? Need it to be able to stream with reduced bitrate.
ProSupport for Business
