bcshark's avatar
bcshark
Initiate
Aug 05, 2026
LCD panel serial protocol correct but not working on Ultra 6 Plus — troubleshooting help?
Referencing this older thread where the LCD protocol was worked out: [ReadyNAS Ultra 6 - Replace OS with any linux distro...]   I'm running Debian on a ReadyNAS Ultra 6 Plus and trying to get the f...
  • bcshark's avatar
    Aug 06, 2026
    ▎ Solved it. Turns out the plain E / L string protocol from this thread (and the Nexenta forum post) is directionally right but missing two details that made it silently fail no matter what baud rate or framing I tried:
    ▎ 1. The panel's PIC firmware needs the port left at its default termios settings — don't stty it to anything explicitly, just open and write.
    ▎ 2. Every line write needs a cursor-position command immediately before it — C <col_hex> <row_hex>\r — even if you already positioned it earlier. Skipping this is why bare L text\r never did anything.
    ▎ I found this by pulling NETGEAR's own GPL source for RAIDiator-x86 (readynas-x86-kernel-modules/pro/lcd/nv6lcd.c in the 4.2.27 GPL release — their live download portal blocks bots, but it's recoverable via the Wayback Machine's CDX API if anyone else needs to dig up old NETGEAR GPL releases).
    ▎ Full command set from that driver:
    ▎ | Command | Meaning |
    ▎ | E\r | Clear screen |
    ▎ | D 0|1|2\r | Backlight off / on / dim |
    ▎ | P 0\r | Stop progress bar (sent at init) |
    ▎ | F 0\r | Font select |
    ▎ | C <col_hex> <row_hex>\r | Position cursor (hex, no 0x) |
    ▎ | L<26-char padded text>\r | Write text at current cursor position |
    ▎ | B 8 A 0 <8 hex bytes> 0\r | Draw an 8x10 disk-status bitmap icon |
    ▎ Disk icons sit at columns 0/8/10 (hex), row 0 for disks 1-3 and row D for disks 4-6. Text lines start at column 18 (right after the icon columns).
    ▎ Working Python driver, port /dev/ttyS1, one open/write/close cycle per command:
    ▎ #!/usr/bin/env python3
    ▎ import os, sys, time
    ▎ PORT = "/dev/ttyS1"
    ▎ DISK_POS = {1: "0 0", 2: "8 0", 3: "10 0", 4: "0 D", 5: "8 D", 6: "10 D"}
    ▎ BITMAP_STD = {
    ▎ 1: "B 8 A 0 7F 41 49 59 49 49 5D 41 7F 0",
    ▎ 2: "B 8 A 0 7F 41 5D 45 5D 51 5D 41 7F 0",
    ▎ 3: "B 8 A 0 7F 41 5D 45 5D 45 5D 41 7F 0",
    ▎ 4: "B 8 A 0 7F 41 55 55 5D 45 45 41 7F 0",
    ▎ 5: "B 8 A 0 7F 41 5D 51 5D 45 5D 41 7F 0",
    ▎ 6: "B 8 A 0 7F 41 5D 51 5D 55 5D 41 7F 0",
    ▎ BITMAP_BLANK = "B 8 A 0 7F 41 41 41 41 41 41 41 7F 0"
    ▎ BITMAP_FAIL = "B 8 A 0 7F 41 63 55 49 55 63 41 7F 0"
    ▎ def _send(cmd):
    ▎ fd = os.open(PORT, os.O_RDWR)
    ▎ os.write(fd, cmd.encode())
    ▎ os.close(fd)
    ▎ def _delay(ms):
    ▎ time.sleep(ms / 1000.0)
    ▎ def clear():
    ▎ _delay(100); _send("E\r")
    ▎ def backlight(mode):
    ▎ _send("D %d\r" % {"off": 0, "on": 1, "dim": 2}[mode])
    ▎ def disk_icon(num, state):
    ▎ bitmap = {"std": BITMAP_STD[num], "blank": BITMAP_BLANK, "fail": BITMAP_FAIL}[state]
    ▎ _delay(150)
    ▎ _send("C %s\r" % DISK_POS[num])
    ▎ _send(bitmap + "\r")
    ▎ def _line(row_hex, text):
    ▎ _delay(100)
    ▎ _send("C 18 %s\r" % row_hex)
    ▎ _send("L" + text[:26].ljust(26) + "\r")
    ▎ def line1(text): _line("0", text)
    ▎ def line2(text): _line("D", text)
    ▎ def init_screen():
    ▎ _delay(100); _send("P 0\r")
    ▎ clear()
    ▎ _delay(100); _send("D 1\r")
    ▎ for d in range(1, 7):
    ▎ disk_icon(d, "blank")
    ▎ _delay(100); _send("F 0\r")
    ▎ line1("ReadyNAS")
    ▎ line2("")
    ▎ if __name__ == "__main__":
    ▎ action = sys.argv[1]
    ▎ if action == "init": init_screen()
    ▎ elif action == "clear": clear()
    ▎ elif action == "line1": line1(sys.argv[2])
    ▎ elif action == "line2": line2(sys.argv[2])
    ▎ elif action == "backlight": backlight(sys.argv[2])
    ▎ elif action == "disk": disk_icon(int(sys.argv[2]), sys.argv[3])
    ▎ Run as root, e.g. sudo python3 nv6lcd.py init or sudo python3 nv6lcd.py line1 "hello".
ProSupport for Business
