Marvell's avatar
Marvell
Logs for BT addon
Hi all
I was looking on RN for the BT logs but I can t find it?
Someone knows where can I find this logs files?
Regards
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Have you checked in the log zip file (Status > Logs > Download all Logs)?
  • chirpa wrote:
    The default BT client does output to log files.
    you mean doesn't?
  • I would recommend using uTorrent or Transmission, which have much greater features and compatibility. The BitTorrent Inc client that was built in is no longer updated by them, we have removed in future firmware releases.
  • Yeah I know....
    I was using for a long time Transmision, but whith one fw updates I had problems with it. So I put in contact with support but they said my client was not supported because it wasn't a official addon....so I changed to supported one......
ProSupport for Business
