azureal
Feb 13, 2023Aspirant
Lost discussions - posts never showing up
Hi Folks,
I have been attempting to post a new discussion topic over the past two to three weeks with out any success.
The new discussion is related to development of OS 6 packages.
I have ...
Sandshark
Feb 15, 2023Sensei
Please do consider still doing development on the ReadyNAS if you have the skills and patience to put up with Netgear not keeping things up to date. We can certainly use more (any?) active developers. But rather than try to go through official channels, I suggest you use GitHub as some others have as a way of distributing your work.
Unfortunately, once a reply has posted or after some time-out (maybe based on how many reads it gets, I don't know), you can't edit a post.
azureal
Feb 15, 2023Aspirant
Thanks Sandshark, I can definitely set up a new repo for ReadyNas stuff. I’ll also have a look for other repos that folks have been committing apps and projects to.
One recent thing I have setup is an installation of Java and Apache Tomcat. While not of much utility for the typical OS6 user, it opens up a world of possibilities for developers of web based applications. I have picked up several inexpensive 314 units over the past year and with 4GB RAM and four cores they are actually very capable low power hosts for Tomcat containers running Java or other containerized VMs.
