davethebb
Apr 06, 2017Aspirant
Media Server for Netgear ReadyNAS ULTRA 2 FW 4.2.15
My unit is probably 7 years old. I about to purchaser a media streaming device (LINN DSM unit for music) and have been informed that I need a media server on the Netgear. Various references like Twon...
mdgm-ntgr
Apr 06, 2017NETGEAR Employee Retired
4.2.15 is extremely old firmware. The first step would be to backup your data, verify your backup is good and to update the firmware.
Also, you can run OS6 on your unit but doing so is not supported.
- davethebbApr 06, 2017Aspirant
If I update the firmware would this include the media server that I require. Could you also explain the benefits of going to OS6 as well. Dave.
- StephenBApr 06, 2017Guru - Experienced User
Free ReadyNAS apps (and "add-ons" for OS 4.2) can be found at apps.readynas.com. There are also paid apps/add-ons at https://rnxtras.com/ (prices are low).
-OS 6 supports both ReadyDLNA and Plex. There's also a twonky app available, but I haven't tried using it myself.
-OS 4.2 only has ReadyDLNA at apps.readynas.com. You can find twonky here if you search, but the version is outdated.
Overall, there are a lot of bug fixes and security updates since 4.2.15. If you want to stay with OS4 you should update the firmware, even if it doesn't solve your media server problem.
OS4 is end-of-life, so there aren't any future firmware updates expected. Getting add-ons (including media servers) to work is getting more difficult over time as the underlying linux libraries on the NAS are outdated.
OS6 is current, and is getting security updates and new features - and even though you won't get support, so far Netgear has made sure OS6 runs on legacy ultras and pros. Almost all OS 4.2 features were carried over, and many new ones were added. Migrating to OS 6 does require a factory reset, so all data would be wiped. If you go with it, I suggest upgrading to 4.2.30 first - I don't recall seeing others migrate to OS 6 directly with firmware as old as yours.
