Munber54
Mar 18, 2021Aspirant
memory for ReadyNas Pro 6 firmware update
Hi. I wrote a lot of stuff below but my main question is what type of memory I need for the ReadyNas Pro 6 and also, Did I do everything I need to do to run the ReadyNas Pro 6 with the latest firmw...
- Mar 19, 2021
Munber54 wrote:
also, every time i log onto the ReadyNas units i get a warning message saying "visiting an untrustworthy website had been prevented"...then i have to click on where it says "I understand the risks and wish to proceed to the website"...I guess that's nothing to worry about?
It is expected. The NAS uses a self-signed certificate, so it cannot be verified by a third party (like the browser).
Munber54 wrote:
Did I do everything I need to do to run the ReadyNas Pro 6 with the latest firmware?
Yes, though you should of course set up your shares and finish your system setup. Also you should put a backup plan in place for the NAS.
Munber54 wrote:
would the Crucial 4GB Model CT2KIT25664AA1067 work? https://www.newegg.ca/crucial-4gb-240-pin-ddr2-sdram/p/N82E16820148249 .
2x2 GB is more cost effective than 2x4GB (and many 4 GB modules are not compatible).
I believe your kit would work, but PC2-6400 (800MHz) is sufficient. Other options are
- https://www.newegg.com/crucial-4gb-240-pin-ddr2-sdram/p/N82E16820148160
- https://www.newegg.com/g-skill-4gb-240-pin-ddr2-sdram/p/N82E16820231207
Mar 19, 2021Guru - Experienced User
