Hamio
Sep 09, 2018Aspirant
Minidlna Error?
I have a ReadyNAS RND4000 running RAIDar 6.4.0 and Radiator 4.1.16.
I'm sharing my MP3s and jpgs using the minidlna (1.1.14) included with that system. It appears that all my Roku devices and ...
Marc_V
Sep 13, 2018NETGEAR Employee Retired
Hi Hamio
Welcome to the Community!
Can you enable Readydlna debug and provide us what is happening? We may have to check further to properly assist you.
Regards
- bedlam1Sep 13, 2018Prodigy
Is there an OS 6 addon for Toggle ReadyDLNA Debug? or a SSH method for doing it
- HamioSep 14, 2018Aspirant
I've downloaded and installed the addon, however, I don't see a toggle on the admin pages. Is this a command line action?
Well, I should've looked a little closer...it's already activated. I'll capture some of the upnp-av.log file and post. Thx.
- HamioSep 18, 2018Aspirant
Marc_V wrote:
Hi Hamio
Regards
Included is a log excerpt after installing the debug toggle.At my PixStar digital frame, I selected local pictures and browsed to the NAS, and requested the PixStar to display all pictures in the folder. The number of pictures in that particular folder number over 2000. The included log is the result of the request.
From what I see in the log, the request from the PixStar is breaking a maximum size. Is there a fix for this? The total number of pictures on my NAS is over 16,000 and I'd like to rotate through them all.
Thanks for any suggestions.
[2018/09/18 18:13:55] minidlna.c:1261: debug: HTTP connection from 192.168.0.26:37644
[2018/09/18 18:13:55] clients.c:271: debug: Client found in cache. [Unknown/entry 0]
[2018/09/18 18:13:55] upnphttp.c:880: debug: HTTP REQUEST: POST /ctl/ContentDir HTTP/1.1
Content-Type: text/xml; charset="utf-8"
SOAPAction: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
Content-Length: 1045
Connection: Keep-Alive
Accept-Encoding: gzip
Accept-Language: en,*
User-Agent: Mozilla/5.0
Host: 192.168.0.4:8200<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/1999/XMLSchema">
<SOAP-ENV:Body xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1">
<ObjectID xsi:type="xsd:string" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">64$2$145$C</ObjectID>
<BrowseFlag xsi:type="xsd:string" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">BrowseDirectChildren</BrowseFlag>
<Filter xsi:type="xsd:string" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">*</Filter>
<StartingIndex xsi:type="xsd:string" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">0</StartingIndex>
<RequestedCount xsi:type="xsd:string" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">0</RequestedCount>
<SortCriteria xsi:type="xsd:string" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance">+dc:title</SortCriteria>
</u:Browse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>[2018/09/18 18:13:55] upnphttp.c:653: debug: SOAPAction: urn:schemas-upnp-org:service:ContentDirectory:1#Browse
[2018/09/18 18:13:55] upnpsoap.c:1907: debug: SoapMethod: Browse
[2018/09/18 18:13:55] upnpsoap.c:1211: debug: Browsing ContentDirectory:
* ObjectID: 64$2$145$C
* Count: -1
* StartingIndex: 0
* BrowseFlag: BrowseDirectChildren
* Filter: *
* SortCriteria: +dc:title
[2018/09/18 18:13:55] upnpsoap.c:1303: debug: Browse SQL: SELECT o.OBJECT_ID, o.PARENT_ID, o.REF_ID, o.DETAIL_ID, o.CLASS, d.SIZE, d.TITLE, d.DURATION, d.BITRATE, d.SAMPLERATE, d.ARTIST, d.ALBUM, d.GENRE, d.COMMENT, d.CHANNELS, d.TRACK, d.DATE, d.RESOLUTION, d.THUMBNAIL, d.CREATOR, d.DLNA_PN, d.MIME, d.ALBUM_ART, d.DISC from OBJECTS o left join DETAILS d on (d.ID = o.DETAIL_ID) where PARENT_ID = '64$2$145$C' order by d.TITLE limit 0, -1;
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 262144. [94 results so far]
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 393216. [195 results so far]
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 524288. [295 results so far]
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 655360. [395 results so far]
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 786432. [495 results so far]
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 917504. [595 results so far]
[2018/09/18 18:13:56] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1048576. [696 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1179648. [796 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1310720. [896 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1441792. [996 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1572864. [1096 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1703936. [1197 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1835008. [1297 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 1966080. [1397 results so far]
[2018/09/18 18:13:57] upnpsoap.c:746: debug: UPnP SOAP response enlarged to 2097152. [1497 results so far]
[2018/09/18 18:13:57] upnpsoap.c:757: error: UPnP SOAP response cut short, to not exceed the max response size [2097152]!
[2018/09/18 18:13:57] upnpsoap.c:1308: warn: SQL error: callback requested query abort
BAD SQL: SELECT o.OBJECT_ID, o.PARENT_ID, o.REF_ID, o.DETAIL_ID, o.CLASS, d.SIZE, d.TITLE, d.DURATION, d.BITRATE, d.SAMPLERATE, d.ARTIST, d.ALBUM, d.GENRE, d.COMMENT, d.CHANNELS, d.TRACK, d.DATE, d.RESOLUTION, d.THUMBNAIL, d.CREATOR, d.DLNA_PN, d.MIME, d.ALBUM_ART, d.DISC from OBJECTS o left join DETAILS d on (d.ID = o.DETAIL_ID) where PARENT_ID = '64$2$145$C' order by d.TITLE limit 0, -1;
[2018/09/18 18:13:57] upnpsoap.c:1967: warn: Returning UPnPError 709: Unsupported or invalid sort criteria
[2018/09/18 18:13:57] upnphttp.c:1216: debug: HTTP RESPONSE: HTTP/1.1 500 Internal Server Error
Connection: close
Content-Length: 420
Server: 2.6.17.8ReadyNAS DLNADOC/1.50 UPnP/1.0 ReadyDLNA/1.1.4
Content-Language: en
Date: Tue, 18 Sep 2018 23:13:57 GMT
EXT:<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>709</errorCode><errorDescription>Unsupported or invalid sort criteria</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
[2018/09/18 18:14:02] minissdp.c:647: debug: SSDP M-SEARCH from 192.168.0.23:33925 ST: urn:schemas-upnp-org:device:MediaRenderer:1, MX: 4, MAN: "ssdp:discover"
[2018/09/18 18:15:08] minissdp.c:647: debug: SSDP M-SEARCH from 192.168.0.23:52342 ST: urn:schemas-upnp-org:device:MediaRenderer:1, MX: 4, MAN: "ssdp:discover"
