longin1
Feb 27, 2015Aspirant
MySQL starting problem - error code: 22002010000
Hi,
I have read a few posts about My SQL problem and I haven't found the resolution of my problem.
I try to install MySQL from Apps option. Everything is fine - MySQL appears on Installed Apps.
When I try to switch the state of it from OFF to ON I receive the following message:
"Application failed initialize, code: 22002010000"
Is anybody there who can give me some tips or know what helps me to resolve this problem?
I know linux OS and I can use SSH.
Thanks in advance.
Thanks in advance.
- AussiehulkAspirant
RN104
Firmware - 6.4.2
MySQL was working perfectly up until last week. After a reboot I get the same error message as the OP. "Application failed initialize, code: 22002010000"
I have tried uninstalling and reinstaling. Rebooted multiple times including after uninstall and then after the reinstall but am gettting nowhere.
Is there a solutions for this?
thank you in advance
- longin1Aspirant127.0.0.1
- banditinozApprentice
I have the same problem, won't start. Uninstalled and reinstalled twice so far.
- mdgm-ntgrNETGEAR Employee RetiredWhich parameter did you change?
- longin1AspirantOK, it is done!
I have changed only one parameter.
http://www.readynas.com/forum/viewtopic.php?f=7&t=54845 - longin1AspirantAnybody?
Please, help me. - longin1AspirantOh, I understand. You were trying to confirm what version I installed. :D
Yes, it is 1.0.1. - longin1AspirantThanks for the answer.
What do you mean "1.0.1 rights"?
I have installed 1.0.1 version but what right are you thinking about?
L - super_poussinVirtuosoyou have 1.0.1 add ons right ?
