dsm1212
Oct 06, 2011Apprentice
NASMonitor: Loadavg problem
Installed NASMonitor along with WhoCares? version of PHP5. I'm using https with Frontview. The launch icons on the addon page don't work. I just get an about:blank window for each. I'm thinking this i...
dsm1212
Oct 07, 2011Apprentice
Couple of problems related to https I might as well report here. There is a force https checkbox in the settings and this works for the main loadavg page, but then the tabs for "server" and "settings" don't work. The problem is those two php scripts don't "require" settings.php for some reason. Adding that require caused other problems so I just added the line "settings['secure_conn']='on';" to both files before the security.php file and it caused them to work for me using https.
thanks,
steve
thanks,
steve
