L-Logic
Oct 31, 2023Aspirant
NETGEAR ReadyNAS 2304 (RR2304) RR230400 Volume Degraded Notification and Can't Connect to NAS
I am receiving email notifications from my ReadyNAS 2304 that indicated: "Volume data health changed from Redundant to Degraded." and then received a second email notification: "Disk Model:ST4000V...
Sandshark
Nov 17, 2023Sensei
While the full log will give more information, the log you posted shows the ReadyNASOS process re-starting on Oct31 and again on Nov 15. Are these associated with you shutting down the unit? Possible forcefully? Or maybe by schedule? There are no entries between Oct 31 and Nov 15, so was the unit off during that period?
If you didn't shut it down, suffer a power loss, or have a power-down schedule, then something caused the OS to re-start. While I've never seen something associated with a drive failure cause that, I suppose it's possible. More often, though, a bad drive ends up making the NAS unresponsive and the user does a forced re-start. While there often isn't much else that could have been done, that can create a corrupted volume.
I'm making some guesses here, and your answers to my questions may fill in some gaps, but this appears to be what happened:
- Drive 2 failed on Oct 30, and the OS believed the drive was removed, so the failure was significant.
- On Oct 30, you re-started the NAS with drive 2 still installed. At that point, the NAS saw drive 2 again (it may have recovered some due to cooling down) and started to try and add it back to the array. But it really still wasn't healthy, so that sync would have been very labored.
- At some point after the re-sync started, probably on Oct 31, you again shut the unit down. You did that in mid-sync (that was likely to fail anyway), and that's a very bad thing to do. During sync of a RAID5, you have no redundancy and the volume is very susceptible to damage.
- So when you powered on again Nov 15, your volume was dead.
L-Logic
Nov 18, 2023Aspirant
To answer the questions:
I did not shut down the server, but it is scheduled to shut down at midnight 12AM Mon - Thu and 1AM on Fri and Sat. I do not know what would have shut it down and I am not aware of any power outages, I am in FL and we tend to have power outages often.
Its possible that my kids popped the drive out on Oct 30th, I did find two of the four drives popped out days later. I did not shut down, it would have been on the power schedule.
- SandsharkNov 18, 2023Sensei
AFAIK, the unit shouldn't shut down in mid-sync. But I now disable auto shut-down before swapping out a drive so it doesn't turn off as soon as it finishes (I like to go in and make sure all is OK first), so I'm relying on memory from some time ago on that. But if yours kids popped one out during a sync, that might cause a problem because the NAS was in mid-write at the time. Popping out a second drive when no writing is occurring normally does no harm, as the volume will go offline preventing damage.
Let StephenB see what tale your full logs tell. A lot is absent from the log in the GUI.
