L-Logic
Oct 31, 2023Aspirant
NETGEAR ReadyNAS 2304 (RR2304) RR230400 Volume Degraded Notification and Can't Connect to NAS
I am receiving email notifications from my ReadyNAS 2304 that indicated: "Volume data health changed from Redundant to Degraded." and then received a second email notification: "Disk Model:ST4000V...
Nov 21, 2023Guru - Experienced User
L-Logic wrote:
I will try 1) if I could get your guidance or may try 2) ReClaiMe after doing my homework.
I can give you the steps for (1) in a PM. If something doesn't seem right when you go through them, it's best to post back with whatever issue you are seeing before proceeding to the next step.
Have you ever used the linux command line before? If not, have you ever used CMD in windows?
L-Logic
Nov 28, 2023Aspirant
Thanks StephenB ... was really busy during the holidays. I have a few weeks of critical work to do and then I will try to work on my server. For now I am just going to shutdown the server and remove it from the rack. I appreciate your support on this. I'll reach back out in a few weeks.
