Xaver
Feb 13, 2010Tutor
Network bridge error
Hi, i've tried to bridge my eth1 with the tap0 device for using it with openvpn in bridging modus. I've executed the brctl addbr command as follows: 'brctl addbr br0' which leads to the followin...
hoogends1
Jul 19, 2010Aspirant
Same problem here:
I'm trying to setup an openvpn server on my Readynas Pro and i get same error.
Any1 got an idea if bridging will work at all on the Readynas Pro ?
I installed openvpn, bridge-utils via apt-get and i got to the point that i had a working routing vpn.
But i want to access all systems in my LAN via VPN, so bridging looked the way to go.
(Not sure if this also possible with routing vpn)
Regards.
Regards.
