Xaver
Feb 13, 2010Tutor
Network bridge error
Hi, i've tried to bridge my eth1 with the tap0 device for using it with openvpn in bridging modus. I've executed the brctl addbr command as follows: 'brctl addbr br0' which leads to the followin...
lurium
Jan 13, 2011Aspirant
Still not working with bridge-utils_1.4-5_i386.deb
http://www.linuxfoundation.org/collabor ... ing/bridge
"You need to enable bridging in the kernel.
Set "networking -> 802.1d Ethernet Bridging" to either yes or module "
nas:~# modprobe bridge
FATAL: Module bridge not found.
So basically the modules is missing, asked yoh-dah for the kernel modules tar.gz that fits the kernel in RAIDiator 4.2.16-T25.
Yes im a crazy beta tester :)
