Xaver
Feb 13, 2010Tutor
Network bridge error
Hi, i've tried to bridge my eth1 with the tap0 device for using it with openvpn in bridging modus. I've executed the brctl addbr command as follows: 'brctl addbr br0' which leads to the followin...
WhoCares_
Apr 26, 2011Mentor
Without the output from "dmesg" or excerpts from /var/log/syslog and /var/log/messages there's not much I can suggest. Maybe there's a background task on the ReadyNAS checking for network connections that is getting confused by the bridge setup but I honestly don't know.
-Stefan
-Stefan
