tarobun's avatar
tarobun
Tutor
Nov 23, 2012
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
tarobun wrote:
It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
  • edmundwatson wrote:
    Can I ask out of interest why you have disabled utp? Is there a missing lib on the NAS?
    2 reasons - First is that utp requires additional lib to be compiled/linked and since this is my first addon, I just wanted a simple and clean compile. The second reason is, as JarnoG mentioned, that the Duo has limited memory and cpu and I wasn't keen on it being overly taxed.
  • @shaggys: in the settings.json file, there is an option named "umask", set it to 0 and the downloaded files will be read/writable for everyone.
    @edmundwatson: Transmission is quite hard on the system resources of the Duo. If options like utp, pex, etc are turned on, it will most likely crash after a while due to this. If you require utp, you can try turning it on and see if Transmission keeps running. You sig says you've upgraded the memory in your Duo, so you should be able to turn a few more features on.
  • Can I ask out of interest why you have disabled utp? Is there a missing lib on the NAS?
    Thanks
  • Hi
    How does one change the owner of the downloaded files?
    I want everyone to be able to remove/move the finsihed torrents.
    Thanks in advance
    //Lasse
  • I was running Transmission 2.42 before, but updating to RAIDiator 4.1.10 broke it. This version seems to work for me.
    Thanks!
ProSupport for Business
