super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
veehexx
May 31, 2010Aspirant
the built in webgui is very limited. it's more of a torrent monitor than an admin panel, hence the use of the transmission remote.
i dont think there's anything special about the dotnet version of transmission remote, just it has the 'add torrent with options' option, which allows you to specify another file location then the default
i've found you still need to run through the .json config file to configure watch folders, passwords, etc. limits can be set via webgui or RPC.
