super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
costasx
Jun 17, 2010Aspirant
super-poussin wrote: preallocation
Number
1
0 = Off, 1 = Fast, 2 = Full (slower but reduces disk fragmentation)
In settings.json.
First of all congratulations for the great work you've put in transmission!!!!
Can you please define what you mean by slower... Will it reduce download speed???
I've copied files from my PC to my DUO a few times and loaded the .torrent file in order to have transmission seed them and it worked fine.
Transmission checked them, reached 100% and started seeding them.
Until a couple of days ago when i copied two Video files around 5Gb each that I had recorded using my Dreambox 800 and wanted to upload to a private tracker.
I created the .torrent file using uTorrent on my PC and then copied files to the DUO and loaded the .torrent file. Transmission started checking the files but stopped on around 98-99% on both files. Of coarse there was nothing to download since it's my files and it never started seeding...
Any ideas why it could happen? I changed preallocation value and rechecked but the same every time.....
I loaded the .torrent file on my pc and it worked fine and started seeding normally....
Thanx!!!
