super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
super_poussin
Jun 20, 2010Virtuoso
veehexx wrote: *ONGOING BUG*
S-P, thanks to charles at tranmission bug trac, there seems to be an issue the way the transmission service stops on the DUO.
i mention this has been happening to me for a while; since around 1.92/1.93. not sure if it's related, but this is possibly around the time you SSH'd into my DUO to investigate a stop/start issue.
charles recommended that i stopped the torrents, waited a few seconds (around 40sec just to be sure!) and then stopped the transmission daemon. restarting the daemon 20seconds later. i then start the paused torrents; torrents resume as normal without any checking.
so, on the face of it, this seems to be an issue with how the start/stop script works on your addon. it appears (to my untrained/uneducated mind), that the daemon is being forcefully & prematurely stopped and therefore not allowing transmission to correctly write the resume data, and so torrents are being rechecked on every daemon start.
i hope that makes sense and you have the time to look into this issue.
i do find it hard im the only one experiencing this issue from both readynas and transmission users, but theres definately something up! :)
if you need SSH access again, then just let me know!
will produce a new version today or tomorrow
