super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
super_poussin
Jul 08, 2010Virtuoso
1) can you post the content of your settings.json and explain with which tool you open it ?
2) did you edit the scripts to add your transmission admin password (same as the one you put in settings.json)
you can also replace your settings.json with
better transmission start/stop script
you have now 2 script you need to modify to start/stop transmission properly (torrents are stopped and restart in the last state after a reboot for example)
scripts are in /c/addons-config/Transmission/ :
transtart.sh
transtop.sh
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"blocklist-enabled": true,
"cache-size-mb": 2048,
"dht-enabled": true,
"download-dir": "\/c\/media\/BitTorrent",
"encryption": 1,
"incomplete-dir": "\/c\/media/BitTorrent\/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"max-peers-global": 200,
"message-level": 1,
"open-file-limit": 32,
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65535,
"peer-port-random-low": 1024,
"peer-port-random-on-start": false,
"peer-socket-tos": 0,
"pex-enabled": 1,
"pidfile": "/var/run/transmission-daemon.pid",
"port-forwarding-enabled": true,
"preallocation": 2,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"ratio-limit": "2.000000",
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-enabled": true,
"rpc-password": "password1",
"rpc-port": 8181,
"rpc-username": "admin",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "\/c\/addons-config\/Transmission\/email_alert",
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 10,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14,
"watch-dir": "\/c\/media\/BitTorrent\/sources\/",
"watch-dir-enabled": 1
