super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
super_poussin
Jul 09, 2010Virtuoso
danielvegas wrote: Did you change something within the last 30 minutes? Re-downloaded after I saw your twitter-update.
edit: By the way, how am I supposed to do a proper update?! Currently I pretty much just select local update under "System"->"Update" and upload the newer .bin, without stopping the add-on or anything.
edit2: Okay, so the version-thing seems to be fixed. Says 10898 now and tracker accepts it. However the "Active"-Tab and the User-Section are gone. So sad. :(
no that's ok
I inform guys who follow me just after responding to your post so version is the same
