super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
danielvegas1
Jul 11, 2010Aspirant
More precise information would help. I'm not sure whether I understand you correctly: Do you already have a .torrent-file or do you try obtaining one directly through the Web Interface? The latter will not work.
Do you get any error messages from Transmission or the tracker?
Once you have a .torrent-file, you can upload it with the "Open"-button in the upper left and Transmission will download the containing files from other users connected to the BitTorrent-network. Transmission however is only a client, which requires input about what files to download, it's not a search engine.
You also need to forward ports in your router (51413 is the standard setting).
