super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Ma2T
Jul 26, 2010Aspirant
super-poussin wrote:
Ma2T wrote: Thanks for your work super-poussin!
I decided to update from 1.72 Lite, to the new 2.02, but it never connected to the interface. Tried disabling and enabling it a few times, and a restart, but still no luck. The torrent creation page worked though. I also set the "umask" value.
Then I tried 2.03 for Sparc (Duo,NV+...) same problem.
BUT 2.01 seems to work without a problem :)
can you download 2.02 official again from this site. it should produce a message in frontview log in case of error during install
Cheers SP, will do.
Also, I'm sure not if its Transmission or not, but I have noticed it won't open the ports automatically. I might just be my router being stupid, but I never noticed the problem before. Port forwarding is enabled in my router and Transmission (GUI).
