super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
sdouek
Aug 09, 2010Guide
veehexx wrote: 1 thing im not sure about:
when you downloaded the .torrent file back from demonoid, and you added it into transmission, did you change the download location to the /c/media/gif/ directory?
by default it will download to the default download location (duh!!) which wont be your /c/media/gif/ location.
if your on windows, then i'd recommend transmission remote todo this - http://code.google.com/p/transmission-remote-dotnet/
heres hoping it's that, because im outta ideas :)
I downloaded the .torrent file back from demonoid. Demonoid changes the file descriptor to it to "nemsfunnygif-[[Demonoid.com]]_6075453.4782.torrent".
Went to another box running BitTorrent not Transmission and started downloading it from there still no activity.
Should I try to copy the "/c/media/gif/" directory to "/c/media/BitTorrent/gif" and see if that works ?
