super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
veehexx
Aug 10, 2010Aspirant
i use my gmail account for email notifcations; it is a simple case of insert your gmail email (g-email?!) into frontview and transmission should work. no further SMTP authentication is required. if you get frontview test email/log alerts then you should get transmission alerts too.
i have found it only working with a recent factory reset of my DUO though, so while i havent tested my theory, it maybe that upgrading from previous versions is a bit buggy.
