super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
joja15
Aug 11, 2010Aspirant
veehexx wrote: i use my gmail account for email notifcations; it is a simple case of insert your gmail email (g-email?!) into frontview and transmission should work. no further SMTP authentication is required. if you get frontview test email/log alerts then you should get transmission alerts too.
i have found it only working with a recent factory reset of my DUO though, so while i havent tested my theory, it maybe that upgrading from previous versions is a bit buggy.
Could it not be executing the email script because of permissions on the email script? Everything else works fine. I am able to download a torrent, add a torrent, etc. I receive all other alerts and notifications through email. For exmaple if I restart the NV+ or have an error installing an add-on it will give me an email. When the torrent finishes though I do not get any email. Is there an easy way to check permissions on the email script?
I also tried changing the transmission start and transmission stop scripts to have my ReadyNAS user id and password. That did not help making the email alert work.
Thanks,
John
