super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
veehexx
Aug 11, 2010Aspirant
MysteryMan wrote: I am really struggling to get Transmission to create a torrent file for me!
Have installed Transmission 2.03 and PHP 1.3. I can get to the Create Torrent web page and enter the following values
Torrent Name: TEST
Directory or File: /c/Media/BitTorrent/Seeding/Sharp End/
Tracker URL: http://www.thebox.bz:2710/announce
Private Torrent: yes
Immediately after I press the "Create Torrent" button I get the following messages.......
Warning: copy(/c/webroot/transmission/archives/TEST.torrent) [function.copy]: failed to open stream: No such file or directory in /c/webroot/transmission/transmission.php on line 21
Result : Creating torrent "/c/webroot/transmission/archives/TEST.torrent" .... error reading "": No such file or directory
Warning: chmod() [function.chmod]: No such file or directory in /c/webroot/transmission/transmission.php on line 28
Warning: chmod() [function.chmod]: No such file or directory in /c/webroot/transmission/transmission.php on line 29
Any ideas? Do I need to create a folder or file beforehand?
:cry: :cry: :cry:
i thought i wouldnt be able to sugest a fix for this.
but i have... remove the [space] in the folder name. ie: 'Sharp End' to 'Sharp_End' or 'Sharp.End' etc
escape character doesnt appear to work either (\). also, ensure you've got the case correct; linux is case sensitive.
works for me :)
looks like SP will have his work cutout when he returns from vacation. im having issues when my DUO reboots/shutsdown that torrents get re-verified on next start still.
i have noticed that the create transmission tool will auto-add it to transmission. since i havent proceeded to upload a torrent, im not sure on the effects with trackers that require you to re-download the .torrent once it's been uploaded. might be something worth noting...
@joja15 - permissions could be a cause. either SSH in and use 'ls -l', or use extplorer to view file permissions.
i've found another possibility; transmission.conf file - ensure the applicable email line is set to 'true'.
im guessing default is nobody:nogroup, 777
