super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
MysteryMan1
Aug 12, 2010Aspirant
sdouek wrote: MysteryMan I recreated your error:
Warning: copy(/c/webroot/transmission/archives/.torrent) [function.copy]: failed to open stream: No such file or directory in /c/webroot/transmission/transmission.php on line 21
Result :
Warning: chmod() [function.chmod]: No such file or directory in /c/webroot/transmission/transmission.php on line 28
Warning: chmod() [function.chmod]: No such file or directory in /c/webroot/transmission/transmission.php on line 29
The reason you are getting this error above is I typed a lower case m instead of a upper case M for the Mp3 directory.
Your error is similar:
I recommend checking your case of each folder and changing the file name to
Directory or File: /c/Media/BitTorrent/Seeding/SharpEnd/TheSharpEnd_Episode1_1991_TVRip_mpeg4_.m4v
Replacing any spaces, dashes and brackets with underscores like I did above.
Heck I would change the file name to SharpEnd.m4v just to be ultra safe and then start adding in the rest to see if that fails.
I also have been looking I believe the "M" Media should be a lowercase "m".
Yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-hi!!!! :D :D :D :D :D :D :D :D :D :D
Did as you suggested by using dead simple names and, bingo, I now have a .torrent file!
Many, many thanks (and also to veehexx)
Let's hope the next stage (of uploading it) works OK!
