super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Ennio1
Oct 06, 2010Aspirant
Hmm.. I factory defaulted my Duo to the latest beta (T49), then removed all available installed add-ons,
installed Transmission 2.10, the two ssh-access add-ons, apt, mc, went through the settings.json
and transmission doesn't seem to even start, even though frontview says it's started.
There is no interface, and the scripts refuse to run because of some errors:
/c/addons-config/Transmission/transtop.sh: line 27: unexpected EOF while looking for matching `)'
/c/addons-config/Transmission/transtop.sh: line 33: syntax error: unexpected end of file
just by the look of these errors, I already see the " ` " character being used where it should be " ' ".
and yes, I already changed port, user, passwd in both scripts, as well as in settings.json.
Update: OK, so the port-forwarding setting has changed from older versions (pre 2.*), or it has suddenly become active. I've got it working now. Or so it seems..
