super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
InTheShires
Dec 11, 2010Tutor
enkrypt3d wrote: How do you disable DHT and peer exchange with Transmission when using a private tracker like supertorrent etc? Thx
Also after a while my uploads don't work... even with the upload limit turned off, the upload rate is 0Kb/s
Disable DHT in the "settings.json" file, which is located in addons-config/transmission-daemon.
Edit the file, and change "true" to "false" in the DHT line. Save and close your text editor.
Also, make sure you disable Transmission in Frontview before you edit the above line. Once you've saved and closed the settings.json file, you can turn Transmission back on in Frontview.
As to your other problem, no idea I'm afraid.
