super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
super_poussin
Jan 07, 2011Virtuoso
gohtraw wrote: so will it overwrite newer versions and thus possibly break other add-ons or will it just look what's installed and try to work with that first?
what do you mean ?
The addon will install the transmission files and all the required libraries.
The addon do not delete libraries so software using older version should work
