super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
Devil1
Jul 05, 2011Aspirant
Jemini wrote:
alex_77 wrote: Guys, need your advice!
Just purchased Ultra 2 plus exclusively for torrents download!
Set it up with 1 2 TB HDD (for now), installed Transmission (2.22.09), installed Remote GUI for MAC
Start downloading
At first (1-2 minutes) everything's OK, but then downloading stops and i see an error in Transmission WEB:
Error: No Data found! Ensure your drives are connected or use "Set Location". To re-download, remove the torrent and re-add it
Downloaded 65 MiB of 40 GiB (0.14%)
What shall i do with it? What data? What Set location?
Did you change the default download folder ( it should be /c/mecia/BitTorrent, etc,) or has recreated the share /media you had removed before install transmission?
First excuse my bad English^ second... I have the same problem.... perhaps somebody give me advice??
and the last in web interface transmission doesn't works(in nas menu) but it tries to download in gui....any advices??
