super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long time to open a new one and prepare the 2.0 :)
roostaar
Jul 29, 2011Aspirant
super-poussin wrote:
roostaar wrote:
super-poussin wrote: roostar : try the last 2.33 version it should work :)
take a look on a post above regarding cookie.txt it will help with private trackers (viewtopic.php?f=36&t=41756&p=314056#p313927)
Hi super
Does the cookie thing spoof the client version from 2.33 to 2.11?
If so, that would be a considered a bann-able offence by the torrent site! :slap:
no it did not spoof only add cookies support if you put your trackers cookies in it
if you need a 2.11 I will try to make a compatible version with 4.1.8
If you could make 2.11 compatible, I would be happy to donate another 5 Euro! :)
If it's a boat load of work though, don't worry. I'm sure the beta will be updated soon enough and 2.11 will become compatible again.
